I have Harman Kardon rceiver AVR 135 and IPOD 5. I tried connecting IPOD to receiver by USB and RCA cable as well but Receiver is unable to read IPOD files.
SOURCE: harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
SOURCE: My Harman Kardon receiver (
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
SOURCE: how to connect a microphone in an harman kardon
The only way is to get yourself a separate karaoke mixer that you can connect to your receiver, or get yourself a small two channel disco mixer
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
