Service reminder is flashing and engine is running rough. Can not find an example of the symbol flashing on the left had side of the screen.
SOURCE: I have a 2005 chrysler
the red light means power limited. the yellow ESP light is part of the traction control system.. if you were on slippery ground its a normal thing to happen if the tires spin
SOURCE: screen is frozen showing only the LG symbol, occasionally flashes
with a frozen phone issue, you may need to reset the software to get it running again. But you might loose your data if you flash the phone. I hope you don't have a problem with the screen. sometimes too, when the memory space is filled up, it freezes up. Take out the battery for some hours and try again. if it does not resume, then you may have to flash the phone to reset it to factory setting. Hope this solves your problem. Cheers!
SOURCE: Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
SOURCE: engine power is reduced keeps showing on the dash
how do you fix the "reduced engine power" light on the dash bard of a 07 Chevy Impala LTZ and "Service Traction Control"?
SOURCE: orange engine symbol on dash stays lit.
Your car is most likely obd2 compliant (in the US everycar built after 1996 is) this means your check engine light could be on for a whole list of reasons, You will need an obd2 scanner to plug into the diagnostics connector to read the codes. Many times car parts places will let you use theres, hoping to sell you parts when you know what needs to be fixed. If the use of free one is not available you can probably buy one off of ebay for not too much. Use the code scanner, write down the codes and google them and/or buy a haynes manual that will explain how to do all these things.
http://www.amazon.co.uk/Nissan-Micra-Service-Repair-Manual/dp/1844251551
