2012 Hyundai Veloster Logo
A
Anonymous Posted on Oct 03, 2014
Where is the OBD2 port on the Veloster?
Went to PepBoys and we couldn't find the port connector.
Ariel Lilah
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2017
Ariel Lilah
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1163
Points
2answers
OBD port location for 1993 Dodge Caravan please?
Link 3 for one that old and OBD1.
OBD2 port Dodge Grand Caravan (1996 - 2000)
https://www.outilsobdfacile.com > Dodge-grand-carava...
The OBD II port is located above the pedals. Go to the OBD2 scanner for DODGE. Dodge Grand Caravan - Pedals. The OBD plug is visible on the left of the hood ...
Where is the OBD 2 port on a 1993 dodge grand caravan?
https://www.answers.com > Where_is_the_OBD_2_port...
Dec 26, 2010 - 1993 is OBDI not OBDII. The connector is under the hood, near the left hood hinge.
2015 Hyundai Veloster turbo power loss, whirring noise.
There appears to be no strip down or servicing information. You just replace then at $700 a go!
https://www.google.com/search?q=Veloster+turbo+strip+down
I was thinking there is probably a shear pin between the exhaust fan and the intake fan. Nothing on my theory.
https://www.google.com/search?q=Veloster+turbo+schematic
Car MFG in feb of 1995 thunderbird lx looking for OBD port ,and do i use obd 2 OR OBD1
the ALDL that is in the picture is and OBD2 connector. some cars at this year had gone to OBD2 and some had this connector installed but still used OBD1 connector for codes and data stream. if you have found both then try both.
Where is obd II port located on 2007 dodge nitro
Have a look on the following link (but notice that it is a right hand drive vehicle in the photo):
OBD2 connector location Dodge Nitro 2006 RHD
The OBD2 port is usually 'within an arm's reach' of the steering wheel.
1helpful
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
No communication through obd connector
Repair Shop that knows how to resolve that issue
OBD2 PORT DOESNT WORK SCAN TOOL DOESN'T WORK WITH MY OBD2 PORT
Try another scan tool on this vehicle to confirm that it is a problem with the port. Then have a technician comfirm that the computer isn't at fault before replacing the port connector.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
