When connecting to internet connects to router but then will not connect to internet. comes up with ip address not acquired?
An Internet Protocol address (IP address) is a numerical label assigned to each connection.You should probably do the setting.Contact the ISP and solve this.You can get your IP address using sites like Ip-details.com
It sounds like your router is not assigning an IP address to the TV. If you have already have DHCP turned on, in the router's settings, then you may need to increase the range. If you are not using DHCP by choice, then you will need to assign a static IP to the TV. You may also need to configure the TV's MAC address in the router's settings, if you are using MAC address filtering.
Are you the person that set up the router, and is this your router? Some additional information is required, to be able to assist you.
SOURCE: router unable to acquire ip address
logon into your router through n/w interface first (ethernet not wireless) using the default IP assignment of the router. Now you can manually assign an I/P to it.
SOURCE: laptop can not connect to router
If you care to try, manually enter IP settings in your laptop as follows:
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
DNS - whatever your ISP is using
In your Internet Explorer >
Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
SOURCE: How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Find your computer's IP address :
Windows 7, Vista, and XP, using the command prompt
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
