Garden Logo
A
Anonymous Posted on Sep 14, 2014
John Deere L130 riding mower w/23hp Kohler Engine,
John Deere L130 riding mower w/23hp Kohler Engine, will only start when fully choked.....and when running, periodically dies when any type of "work" is put on the motor(engaging blades, driving forward/reverse etc.)
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,917 Answers
  • Posted on Sep 15, 2014
charles beach
Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570518
Points
3010
Need carb rebuilt one problem may need valve job carb rebuild 80.00 valve job 100.00 per cylinder have to take in to shop for this
1 Related Answer
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 02, 2009
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Why won't my 2007 John Deere L130 turn over?
check your safety devices, ie: seat switch, Transmission position switch, and of course, the clutch/brake pedal switch. be certain that the blades are not engaged when attempting to start the mower
I have a Z445 with a Briggs & Stratton 23 hp V twin, the air filter will not seal, lets trash into engine. It smokes, uses lots of oil. Can I put a Honda or Kohler on it, don't want another B &...
Hi, yes you can. You will need to take the model, type and code numbers with you to a Kohler or Honda dealer. Either will have a listing on an equivalent engine. Regards Phil.
7helpful
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
3helpful
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Top Garden Experts
Jay Finke
Jay Finke
john h
