1990 Buick LeSabre Logo
John Darrell Norman Jr. Posted on Sep 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix reverse problem.
1990 Buick Lesabre 6 cylinder. Reverse problem. Not yet able to fix transmission. Not sure why reverse quit on me. After I got the car I could put it in reverse and drive backwards fine. Then few weeks later I put it in reverse and tires wouldn't move. Give car gas and nothing but engine reving. I recently checked fluid and it is getting little blackish. I can't afford a rebuild or replace. Not sure why my reverse went out.
james
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 125 Answers
  • Posted on Sep 14, 2014
james
Expert
Level 2:
Filmmaker:
Answers
125
Questions
0
Helped
54550
Points
298
It sounds like you need a rebuild. blackish fluid indicates clutch failure.
Testimonial: "It is a automatic no clutch. Only problem is reverse. Drives fine. Not putting all the money for a overpriced mechanic to fix it. I had a car with no reverse before for over a year. I can deal with it. Thank you for advice."
1 Related Answer
desertracer
  • 450 Answers
  • Posted on Jul 01, 2014
SOURCE: 1990 Buick Lesabre no reverse.
This sounds like an internal problem .. possibly a broken hub on the clutch pack Standard GM L460 problem..call a couple of trans shops in your area and ask their assessment and price a rebuild.
1helpful
1999 Buick LeSabre. The car makes a soft grinding noise only when the car is moving in reverse. The under-carriage is getting quite rusty. Sometimes I smell gas.
Sound to me you might have a small gas leak or your exhausts.sounds to me like it could be transmission is going out.
4helpful
2answers
Bought a 1990 Buick lesabre When I shift into reverse it knocks real hard when connecting Shakes the whole car Every other gear hooks up great
Try some Lucas in the transmission fluid. It can help minor problems sometimes, otherwise time to either head to the junkyard for another transmission or the shop to get it rebuilt.
1992 Buick Lesabre that will not go in reverse. It goes slow in drive
The bands in the transmission are bad,you need to replace or have that rebuilt
My 2003 Buick Lesabre is stuck in Drive gear.
Here's the link and I'm sure you will get the solution of your problem
2003 Buick
Reverse lights wont work on 94 buick
should be a switch either on or in your transmission possibly has go out or have a bad connection
2helpful
Serpentine Belt Tensioner
take belt off then make sure you have the right size socket and breaker bar to loosen the bolts on the tensioner and do everything in reverse to put new on
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
