The new unit leaks around the toilet to bowl gasket
There is a rubber gasket between thaa toilet and bowl,or well known as the water closet.,check it if you put it on place.,or maybe you had put it flip top..?
if you are sure that you had been put it correct but still leaking,try to clean the faceof toilet and water closet where the rubber gasket will be placed on,also clean the rubber gasket itself,it must be free of dust, or sand...then place it on place and tighten the plastic bolts and nuts to fit the joints...
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
SOURCE: Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
SOURCE: correct tank to bowl gasket for Orion toilet
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
