I have a after market JVC radio, it has worked fine for months now. However, recently it just randomly shut off and hasn't worked since. I have check all the wiring directly to the radio. Also I have checked the radio fuse and the regular fuse panel radio fuse. Both are fine what else could it possibly be?
SOURCE: 1998 Chevy Suburban radio troubles...
Hi Janie,
If the radio powers up, it's not a fuse problem. At least not with the radio itself. The door locks are most likely unrelated. We can address them separately. One thing at a time though.
My first suggestion would be to check for an engaged mute option. If that isn't it, my 2nd choice is the box that you mentioned, that the radio connects to. That is what is drawing my attention.
However I need to know more.
A bit of Question and Answer is needed to help you out. Just comment me back with the answers. OK?
Get back to me and we'll get you fixed up
Mike
SOURCE: no sound for door chimes or radio
Is the radio stock? If so have you tried getting a different OEM radio?
SOURCE: Rear-Left Speaker Not working
Speakers inop are very common in trailblazers. It is 99% of the time the speaker.
I had a similar problem with a 2001 Saturn. We checked every fuse and they were all fine. We finally did a 'reset' on the car's computer by disconnecting the battery and reconnecting it a few minutes later. Everything was back to normal after that.
SOURCE: My dash lights don't work.
this got easy after a while 2 ways, i had friends who would not take the time to spend 8dollars to buy a harness connector for a new cd player and would splice everything together like takeing the red and yellow wires and connecting them all together as one. this drains ur battery unless ur cd player can completly power down by the power button not all do... but keep this in mind on GM cars the 2 wires of the same wires like purple the one with a black stripe is ground they go together stripe on stripe also there is 2 extra wires one is ORANGE and BROWN u dont need these dont even mess with them even if u have a connector block them off THESE TWO COLORS IS FOR FACTORY STEREO IF SO THESE WIRES CAN AND WILL MAKE IT SO U DONT HAVE DASH LIGHTS so always buy a connector ond dont mess with these wires block them off and dont ground them out.
