Fan oven door not closing properly anymore and not 'snapping shut' as top oven still does.
SOURCE: smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
SOURCE: Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
