Tel-Time Oval Talking Alarm Clock Keychain White Logo
A
Anonymous Posted on Sep 03, 2014
How do I turn the alarm off?
The talking clock has three buttons on the back (mode, hr, min). How do I turn the alarm off? Talking clock was purchased about 4 or 5 years ago.
Have a ONN clock radio model ONA15AV101 - how do I set the clock
THE UNIT TO POWER
Plug AC power cord to the AC wall outlet. Before switching on the unit, make sure that the voltage of your
electricity supply is the same as that indicated on the rating plate.
BATTERY BACKUP
Insert 2 AAA batteries into the battery compartment. Be sure to observe the proper polarity (the "+" and
"-" signs) as indicated inside the battery compartment.
In case of power failure or interrupted AC power, the current time, alarm time settings, and stored radio
stations are preserved in the memory of the unit using the battery back-up function.
SETTING THE CLOCK
1. With the unit in CLOCK mode, press and hold the CLK/MEM button for about 1 second, the time will
begin to flash on the LED display.
2. Press the ?/HR button to adjust the hour.
3. Press the ?/MIN button to adjust the minute.
4. When the correct time is selected, press the CLK/MEM button again to confirm.
SETTING THE ALARMS
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM
time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently
set radio station. The alarm buzzer or radio indicator will light up.
SNOOZE FUNCTION
1. Whenever the alarm (radio or buzzer) activates, it can be temporarily suspended for a short period of 9
minutes by pressing the SNOOZE/SLEEP button once.
2. The buzzer or radio will then automatically activate again after the 9 minutes SNOOZE period has
ended.
3. This procedure can be repeated for up to approximately one hour.
DIMMER FUNCTION
Press the DIMMER button to change the brightness of the display.
TURN OFF THE ALARM
When the ALARM activates, press the ALM OFF/SOURCE button to turn off the ALARM.
LISTENING TO THE AM/FM RADIO
1. Press the ALM OFF/SOURCE button to select the FM or AM mode.
2. Press the ?/MIN button or ?/HR button step by step to tune to the desired radio stations.
3. Press and hold the ?/MIN button or ?/HR buttons for approx. 1 second, it will start to search the
next radio station in the direction of the search. The search operation simply finds stations with
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
6helpful
I have an ultmost model 6695 talking alarm clock. It is supposed to "talk" on the hour and on the alarm. However, it has stopped. The mode has 3 options: time, 12/24 hr, and alarm. I...
Make sure the clock is in the normal clock-display mode, not in a "set" mode. Press the minute key (again, while not in a set-anything mode) and you will see the hourly announcement toggle on and off. The person who designed it that way needs a good kick right in the bracket.
Aug 18, 2011 • Watches
1helpful
Model 31320 SkyScan Equity Time Clock -- it did not change with DST but I cannot figure out how to manually set the time. Back of clock shows 4 long...
You press and release the mode button, then press the adjust button. This is what the instructions say to do. However, I see that you don't have an adjust button listed. I would try pressing and releasing the mode button, then pressing the ZONEDATE button and see if that will do it.
If this works, please place a vote for me. Thanks,
Handie Andie
Mar 27, 2011 • Vacuums
2helpful
2answers
Somehow the clock is displaying 24 hour time format. I want to get back to 12 hour format. How?
Push the mode button twice to enter the "set time" mode. Once the digital display is blinking, keep pushing "mode" until the PM display section in the upper left corner comes on. Once that happens you are back to the 12 hour clock. To set the clock, use the 1-4 buttons to set the hours and minutes.
Hope this helps.
76helpful
5answers
Voicezone talking pedometer instructions, turn off alarm
Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
1helpful
2answers
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
2answers
Casio PQ-50 travel alarm
Hi, I haven't solved th eproblem, but it's such a small thing and I will just perservere - it's not worth taking your valuable time. Thanks, Rob
7helpful
2answers
Bratz talking alarm clock
I purchased a Bratz talk back alarm clock for my daughter, however, she threw away the instructions.
Can you tell me how to work the clock to hear it talk back or to activate the talk back voices.
Top Tel-Time Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tel-Time Home Expert? Answer questions, earn points and help others
