This receiver has served family room AV system well for 13 years. I use second speaker set outdoors. I really want to hook in iPod for daughter's grad party June '15. If not may have to upgrade before then.
Look for a bluetooth device for AV receivers. Maybe something like this??
http://www.amazon.com/HomeSpot-NFC-Enabled-Bluetooth-Receiver-System/dp/B009OBCAW2
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
SOURCE: I have a JVC rx-6032v
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
SOURCE: How much is a JVC RX 750v worth?
I have this same unit. It is many years old, and does not handle any modern codecs, nor home theater duties. It was, however, a very good unit for its day. If I were to sell mine, I would not accept less than 100 US with remote.
I have a 5000vbk with my iPad hooked to it made my own cable took headphone cable cut off one end attached rca backed plug to aux works and sounds great cost 8.00$
