2002 Ford SVT Focus Logo
A
Anonymous Posted on Aug 14, 2014
Is there a ford focus timing marks single overhead cam diagram
Is there a diagram picture for timing marks on Ford focus single overhead cam
Eric Justad
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 41 Answers
  • Posted on Aug 15, 2014
 Eric Justad
Contributor
Level 1:
New Friend:
Night Owl:
Answers
41
Questions
Helped
8945
Points
88
Depending on trans and engine mount type the mark my be on flywheel but generally most cars it is located on the belt pulley attached to crank rod, center bottom one on engine block. the timeing mark should be visable from top looking down. if you use a big ratchet to turn over the engine by hand and go slowly, you should see thhe marks pass as you do so.
5 Related Answers
Anonymous
  • 120 Answers
  • Posted on Aug 25, 2008
SOURCE: tourque specks
Good day;
Is it the rod connecting cap you talking about if so here is the specs 89 lbs (120 N.m) If this it not you are looking for please let me know.
Cheers.
Anonymous
  • 11 Answers
  • Posted on Nov 06, 2009
SOURCE: I need a diagram for a 2.0 L. 2003 Ford Focus duel
Hope this helps....Not sure about your exact equipment in the vehicle, but this should help I hope
Patrick Rayome
  • 1757 Answers
  • Posted on Mar 19, 2010
SOURCE: timing marks for 2000 ford focus
Click on the following direct Link.
With the DOHC you will need the Camshaft Sprocket Holding Tool and Camshaft Alignment Tool.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/focus/2000_ford_focus_timing_belt_diagram_marks.htm
Anonymous
  • 122 Answers
  • Posted on May 28, 2010
SOURCE: diagram for timming belt on 2002 ford focus 2.0ltr
there isnt marks!the cam pulleys have do nothing with timing!remove the valve cover and see in the other end of the camshafts and find two eccentric cuts!turn the crankshaft to the top dead point on the cylinder 1 the two cuts must be in the same line on the upper or lower side.you need aspecial tool to lock the camshafts and another to lock the crankshaft!this is the timing procedure!now you can change anything you want!note!the cam pulleys are conejointed to the camshafts!no marks no pins no safe pins etc.isnt difficult but complicated simple!
Testimonial: "thank you"
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Feb 10, 2012
SOURCE: how to find and set timing marks for 2003 ford focus 2.0 16 valve with dual overhead cams ztech engine
I do not have a diagram but i do have a site with very detailed instruction on how to set the whole thing up correctly, just click HERE
How to find and set timing marks for 2003 ford focus 2.0 16 valve with dual overhead cams ztech engine
6helpful
2001 Ford Focus over heating, did not hear cooling fan running after shut down could this be the fan relay or something else?
Yes, the relay or the fan itself. You have to let the car get hot to test. Please tell me--do you have the ZETEC engine or not? Single overhead cam or dual overhead cam? Also, do you have A/C or not. I will send you the wiring diagram and some troubleshooting steps.
3helpful
2000 ford focus firing order from distributor
1-3-4-2
there are 2 coil setups. single overhead cam is like this:
Dual overhead cam is like this:
4helpful
2answers
I have a 2001 ford focus SE is my engine is a single or dual cam?
Look at the 8th digit on the vin #
3 = Duel
P = Single
Where do I look to find out if my 2000 ford focus LX is a single overhead cam or a double overhead cam
if it says split port 2.0 on the top of the engine, it is a single cam. anything else like zetec or duratec is a double.
3helpful
2answers
Diagram for timming belt on 2002 ford focus 2.0ltr
2000 ford focus 2.0singe overhead cam timing belt remove and installation
single overhead cam ?? is this the old type engine ?? or a ford endura diesel
1helpful
Changing Spark Plugs
2.0L SOHC (single overhead cam) AGSF34EE plugs gap 0.054
2.0L DOHC (dual overhead cam) AZFS32FE plugs gap 0.050
The plug numbers are the motordraft numbers
I am installing a new timing belt in a single overhead cam engine code P
the timing marks on a zx3 are pretty pre fab ounce you have the timing bar(303)and the timing plug remove the crankshaft pulley and the line should be at 11 on a clock line up with o on the word front that along with the bar and plug will be able to properly find tdc for all piston heads.then run it fromthe left cam sprocket all the way round till the tensioner.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
