What causes the code disc error whenever i insert a cd
Usually this is caused by the laser getting lazy or dirty. You could try taking the lid off and carefully cleaning the laser, (You could get lucky), but this is usually just a token gesture. I have had success with boosting the voltage to the laser but this in turn produces alignment problems and then must be recalibrated and is still only a temporary solution. If you are attached to the unit have it repaired. It is a nice piece of equipment. Otherwise look out on Ebay for a moderately priced replacement. Cheers Bob
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
SOURCE: TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
SOURCE: need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
SOURCE: help with denon dn-s3000
CD lens cleaners are not to be used with these slot load cd players (as per the manual).
Please visit www.denoindjforums for further help.
SOURCE: Hi. My denon dn s3500 just says disc error when I
clean the lens...if it does not work replace the lens.
