Dear,
The msg alert tone depends on the current sound profile of your phone (like normal, silent, driving etc).
1. Go to main menu -> settings -> phone profiles. You should find all the profiles available in the phone. For example, we will change the msg alert tone for 'normal'.
2. Tap on the box with the double arrow (>>) symbol next to normal. You should enter a screen saying call alert type, voice call ringtone etc.
3. There is a drop down menu at the top right side of the screen. Tap that and select 'new messages'.
4. 'message alert type' should be melody or vibration & melody, depending on your preference.
5. now select 'message alert tone'. The phone has a number of tones already stored. Select one of these.
6. Or select 'sounds' at bottom right and browse to any file you want to set as message alert tone instead..
7. Save and exit !!
----pls rate if you find it useful-----
Regards,
Samy
SOURCE: message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
SOURCE: samsung s8300v - how to change message and key tones
There is a fair few steps involved, but here goes :
Open you Menu, then Settings, then Phone Profiles, then clock on the ">>" Symbol beside whichever profile you mostly use (probably Normal). From there you can edit your call settings (alert type, ringtone etc).
At the top right of this screen is a drop down box where you can select from 3 menu's, one is the options menu you are currently in, the other 2 involve messaging and phone sounds. hope this helps
SOURCE: how can i change the message tone on my samsung
i' want to change my ringtone message.of my samsung gt.s 5620,monte pls help
SOURCE: how do you change the message tone on the samsung
Settings > Phone Profiles > Normal > New Message > Melody Alert Tone
Enjoy!
