there is a 1 year warranty on this product, so i expect GE to honour it. thanks. there is a 1 year warranty on this product, so i expect GE to honour it. thanks.
You can't post conmments that contain an email address.
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
The DTMF [Dual Tone Multi Frequency] tone dialing system operates on Direct Current [DC] and is DEPENDENT ON the PROPER POLARITY of the two phone conductor wires!!!!
IF the polarity is reversed, ONLY the PULSE DIALING WILL WORK!!!!!
USUALLY the Tip and Ring wires are colored Red and Green [I think -- it's been a lotta years!!!!!].
HOWEVER, color really doesn't matter as USUALLY ONLY TWO WIRES ARE CONNECTED TO THE PHONE SO REGARDLESS OF COLOR, JUST REVERSE those two wires.
Try reversing the two wires, and then switch the phone to tone dial and try it. That MAY solve the problem!
If that doesn't solve the problem then it's beyond me!!!!!
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones:
Menu > Settings > Initial Setup > DTMF
When you dial a number, your phone sends
it to your network as Dual Tone Multi
Frequency (DTMF) tones.
To send DTMF tones during a call, just
press number keys or scroll to a number in
the phonebook or recent calls lists and
press Options > Send Tones
Is there dial tone at the jack where you are plugged in?? Are you sure?
Is this a pulse/tone phone? Do you have a pulse or tone line? Have you made the correct setting? Is the RJ-11 connections solid? Have you tried the wire on another phone and proved it is good? Is there a separate power suply for the phone or does it get its power from (a) the radio or (b) from the phone company?
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
the links tat r there inside the phone are shorted as they r very thin threads like..just go to a repairer and he will resoulder the links and the problem will be solved..for temporary work just open the phone and remove all dust ..mostly keypad will start working
