SOURCE: I just bought my Garmin Nuvi 200 and just stays black screen?
My Garmin 200 did the same on two occasions. On the bottom to the left of the serial number is a tiny reset button. Press that using a pencil point and all will be reset. And you don't lose any map data, so don't worry!
SOURCE: Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
SOURCE: Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
SOURCE: My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
SOURCE: Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your
device to factory settings or delete any map updates. The reset button will
switch your device off if you are unable to switch the device off by the power
button. It will not erase any data on the device.
The reset button on your nuvi will switch
the device off. The reset button can be used to switch your device off if the
screen is frozen and you are unable to switch the device off by the power
button.
To reset a nuvi 2xx:
To reset a nuvi 3xx or 6xx:
The device will now switch off.
