Motorola Mobility W377 Met Silver/Pink Bluetooth Camera FM Unlocked Cellular Phone Logo
A
Anonymous Posted on Jul 24, 2014
T mobile apn setting - Motorola Mobility W377 Met Silver/Pink Bluetooth Camera FM Unlocked Cellular Phone
  • Official Brand Answer 3,100 Answers
  • Posted on Jul 24, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685075
Points
13487
2answers
I have assist wireless and need apn settings for my lg g4 please? Thanks so much.
APN & data settings
  1. From any home screen, tap Apps > Settings.
  2. If using Tab view, select the Networks tab.
  3. Under 'CONNECTIVITY,' tap More.
  4. Tap Mobile networks > Access Point Names.
  5. If available, tap the T-Mobile US APN (the bullet point fills with green).
https://www.t-mobile.com/support/devices/android/lg-g4/network-apn-and-volte-lg-g4#steps1
tip
Gprs & MMs settings for england cellphone networks
&gt;T-MOBILE GPRS SETTING <br /> <span> </span>#Account Name - T-MOBILE GPRS <br /> <span> </span>#Username : user <br /> <span> </span>#Password: wap <br /> <span> </span>#Homepage: http://wap.t-mobile.co.uk/ <br /> <span> </span>#GPRS APN address: general.t-mobile.uk <br /> <span> </span>#Gateway (IP) address :149.254.001.010 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Port number: 9201 <br /> <span> </span>#Authentication: Normal <br /> <span> </span>&gt;T-MOBILE MMS SETTING <br /> <span> </span>#AccountName:- T-Mobile <br /> <span> </span>#Data Bearer:- GPRS #User name:- mms <br /> <span> </span>#Password - T-mobile tell you this when you register <br /> <span> </span>#APN:- general.t-mobile.uk <br /> <span> </span>#IP address:- 149.254.211.10 <br /> <span> </span>#MMS Server:- http://mmsc.t-mobile.co.uk/ <br /> <span> </span>&gt;ORANGE GPRS SETTING <br /> <span> </span>#Account Name :- ORANGE GPRS <br /> <span> </span>#Homepage: http://orange.multimedia/ <br /> <span> </span>#APN address: orangewap <br /> <span> </span>#Gateway (IP) address : 192.168.071.035 <br /> <span> </span>#Username : Multimedia <br /> <span> </span>#Password: Orange <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: NormaL <br /> <span> </span>&gt;ORANGE MMS SETTING <br /> <span> </span>#AccountName:- Orange <br /> <span> </span>#Data Bearer:- GPRS <br /> <span> </span>#APN:- orangemms <br /> <span> </span>#User ID:- Orange <br /> <span> </span>#Password:- Multimedia <br /> <span> </span>#IP Address:- 192.168.224.10 <br /> <span> </span>#MMS Message Server:- http://mms.orange.co.uk/ <br /> <span> </span>&gt;VODAFONE GPRS & MMS SETTING <br /> <span> </span>#Account Name - VODAFONE GPRS <br /> <span> </span>#Homepage: http://wap:1999/vodafone.wml <br /> <span> </span>#APN address: wap.vodafone.co.uk <br /> <span> </span>#IP address: 212.183.137.12 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: Normal <br /> <span> </span>#Security: Off <br />
on Jan 11, 2011 • Cell Phones
Apn settings for Safety Net/Lifeline on AT&T Samsung J7
these are apparently the settings
https://www.fixya.com/support/t26922303-apn_settings_safetynet_wireless_lifeline
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type:<Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
this is the instructions for samsung on how to change settings
https://www.t-mobile.com/support/devices/android/samsung-galaxy-j7/network-apn-and-volte-samsung-galaxy-j7#steps1
Life wireless apn settings for at&t huawei ascend xt2 H1711
APN & data settings
    • Name: T-Mobile US
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • MVNO type: None
Switch 2G / 4G
    • WCDMA/GSM
    • GSM only
  1. From any Home screen, tap Apps > Settings >Data usage.
From - https://support.t-mobile.com/docs/DOC-28547 Network APN Kyocera DuraForce XD
2answers
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
    • Name: T-Mobile US
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • MVNO type: None
Switch 2G / 4G
    • WCDMA/GSM
    • GSM only
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
1helpful
How can I make apn settings?
NET10 operates on either the T-mobile network or AT&T network here are the APN setting for both carriers:
Net10 AT&T APN service
If the one you are running on is AT&T, please enter the following values on the APN:
APN: tfdata
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
Any fields not noted above should be left blank
Net10 T-Mobile APN service
If on the other hand your net 10 service is based on T-Mobile network, use these values instead:
APN: wap.tracfone
MMSC: http://mms.tracfone.com
MMS proxy: Leave in blank
MMS port: 8080
To set the APN go to Settings>More>Mobile networks>Access Point Names>Menu>New
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 • Cell Phones
2answers
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
