Water Pik Aqualink Rs4 Package - Pool and Spa Combo Logo
A
Anonymous Posted on Jul 20, 2014
Why are all lights are on control panel - Water Pik Aqualink Rs4 Package - Pool and Spa Combo
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Water Pik Master 1,448 Answers
  • Posted on Aug 03, 2014
David Spradling
Water Pik Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
519176
Points
1901
Turn system off pull off front cover take the red 4 pin plug off turn back on if all lights go off there is either 2 wires touching by plug or someone cutinto the cable also check to see if the reset button isnt stuck if these arent the problem probablythe bezel board is bad you might need a professional
Our control panel indicator lights do not light up when pool comes on but may come on during the cycle. No consistency.
If the control panel indicator lights on your pool system do not consistently light up when the pool is turned on, it could indicate a potential issue with the control panel or the electrical connections. Here are some troubleshooting steps you can take:
1. Check Power Supply: Ensure that the power supply to the control panel is stable and consistent. Make sure the power source is providing the correct voltage and that there are no loose or faulty connections.
2. Inspect Wiring Connections: Verify that all wiring connections to the control panel are secure and properly connected. Loose or damaged wiring can cause intermittent issues with the indicator lights.
3. Clean and Inspect Control Panel: Check the control panel for any signs of dirt, debris, or corrosion. Clean the control panel and its components using a soft cloth and a mild cleaning solution. Inspect for any visible damage or loose components.
4. Test Indicator Lights: While the pool is running, observe the control panel and try to identify any patterns or triggers that may cause the indicator lights to come on. Gently tap on the control panel to see if it affects the lights. This could indicate a loose connection or a faulty component within the control panel.
5. Consult a Professional: If the issue persists or you are unable to identify the cause of the inconsistent indicator lights, it is recommended to contact a professional pool technician or the manufacturer's customer support for further assistance. They will have the expertise to diagnose and resolve the specific issue with your pool control system.
Remember, working with electrical components requires caution. If you are not experienced or comfortable working with electrical systems, it is best to seek professional help to avoid any potential safety hazards.
Apr 06, 2023 • Pool & Spa
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 • GE Dryers
1helpful
Whirlpool duet dryer
Oct 22, 2013 • Dryers
G1022
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 • Dishwashers
I HAVE 3 NOS DB IN DIFFERENT LOCATION FOR LIGHTING HOW TO MAKE 1 TIMER PANEL TO CONTROL THOSE 3 LOCATION OF DB
What is NOS DB?
You want to control 3 locations of lights using 1 control panel.
Are you going to run wire from each light to the control panel?
Are you using 120Volt or 240V? What voltage are you using?
Model number of control panel is unknown, and which timer is inside control panel is unknown. Copy following link for overview of control panels.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2helpful
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
2helpful
The controls locked is displayed. what causes this and how do i get the controls unlocked.
24helpful
4answers
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Top Water Pik Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Water Pik Pool and Spa Expert? Answer questions, earn points and help others
