Begin with the basics....
INSPECT COOLANT LEVEL,
Low ????,PRESSURE TEST SYSTEM,
PRESSURE TEST RADIATOR/EXPANSION TANK CAP,
INSPECT DRIVE BELT(s),
INSPECT COOLANT HOSES,
INSPECT HEATER HOSES,
INSPECT BYPASS/MISC. COOLANT HOSES/PIPES,
TEST THERMOSTAT OPERATION,
INSPECT RADIATOR COOLING FAN(s)/CLUTCH OPERATION,
INSPECT CONDENSER/AUXILARY COOLING FAN(s) OPERATION(s)
INSPECT RADIATOR & CONDENSER FOR DEBRI,
OBSERVE COOLANT TEMPERATURE GAUGE OPERATION,
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
SOURCE: 2000 ford excursion v10 stall
Had the same problem, did all the checks, alt and battery, found alt bad, changed alt and have not had any issues since.
SOURCE: ford ranger truck overheating
I have had this happen with my ranger. Changed everything I could to try to fix the over heating. It turned out that I had a small leak in my head gasket and it was allowing exsaust gas to go into the cooling system witch was over pressurizing it. Also the air from the exsaust will heat up much faster than liquid making your thermostat to read hot and will not be able to blow hot air in the cab because there is no liquid going to the heater core. This happened to me when my blet came off and I tryed to make it home. If you had it over heat for a long peirod of time it may have ripped the head gasket.
SOURCE: 1997 bmw z3 conv. 1.9 overheated, changed
hi jasso, I would recommend checking the water pump if you see no flow in the radiator. Make sure when you fill up the cooling system, that you fill it cold, and that the vent screw in the radiator is loose. fill system until fluid comes out the vent screw. tighten the screw, start the car and have someone run at 1500rpm and check for flow.also, make sure that you have your temp setting full hot and blower on middle speed so that you don't trap air in the heater core.
SOURCE: overheating,reserve coolant tank boiling
Ford 2000 Taurus
To solve the problem you have the things to do in this order;
) When the engine is cold top off the radiator with fluid. (When the pump was replaced the fluid should have been also)
) Make sure the radiator fluid has anti-freeze in it. This is also anti boil also !
) Add fluid to the overflow reservoir.
) Make sure the drive belt was replaced on the water pump.
) With the engine running, you can add fluid to the radiator for the first minute or so. You want to get air pockets out.
) Replace radiator cap.
) Let car warm up. When it's hot you should get the radiator fan coming on.
) When it get hotter the air-conditioning fan may come on.
) If the fan does not come on, the heat sensor is probably bad.
) If all fans come on, and it overheats, you may have a bad thermostat. Trace the upper radiator hose to where it connects to the engine. That's where it located.
Do not operate the engine when it overheats, You will damage the head gaskets and cause radiator fluid to leak into the cylinders.
If you smell radiator fluid in the exhaust fumes, it may already be leaking.
