Ovens Logo
Don Posted on Nov 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Temp. problems on a GE wall oven
I have a GE wall oven 24" electric jrp20. When I turn it on to any temperature. the readout will climb to what I had set it for, but it the oven is not as hot as it reads, then I set the temp. to 500 and I after a while I got a F2 error that I looked up online and it showed the temp. went over 600. What could be the problem? Thanks!
  • 2 more comments
  • Don Nov 07, 2007
    It is Model # JRP20BOJ1BB & if it helps the s/n is VG606887Q. Thanks!
  • Don Nov 07, 2007
    Is there any way of testing this before I replace it? Thanks!
  • Don Nov 16, 2007
    I have tried to rate this as a fixya! but for some reason it won't let me. So I decided to add this note:
    Thank you for all your help!!!!!!! All your info you gave me worked, I had ordered the new part, installed it and I now have a working oven & a very happy wife!!
    Thanks again! :-)
  • Anonymous Mar 18, 2014
    turn on oven it cuts off restart as the temperature climbs it will stay on when it is closer to temp
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
535
Points
How do I take out the glowbar wire? I have taken it off the gas tubing.
Anonymous
Level 3:
  • Master 473 Answers
  • Posted on Nov 07, 2007
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451992
Points
1483
Give me the complete model # from the tag on the oven and I will look into this for you.
  • 1 more comment
  • Anonymous Nov 07, 2007
    If you are sure that the bake element is coming on and you have no problems with voltage to the oven I would replace the oven temp sensor. It can be remove from inside the oven by taking out 2 screws. Pull out harness and all and just plug in the new one. It is # 253 on this diagram http://www3.sears.com/imaging/ImagePageJ...& cost is $73.49 from this site http://www3.sears.com/. Part # is WB21X5301.
    You can use an ohm meter to check resistance on the probe. If it checks open then you know it is bad. Normal value is 1091 ohms at 75 degrees F. The problem is the resistance changes at higher temps. and you don't know what it is doing at those high temps. Unless you want to take the time to put a thermometer in the oven and check it according to the scale at different temps. You can use this scale if you want to try that:
    *RTD SCALE
    Temperature (°F)
    Resistance (ohms)
    32 ± 1.9
    1000 ± 4.0
    75 ± 2.5
    1091 ± 5.3
    250 ± 4.4
    1453 ± 8.9
    350 ± 5.4
    1654 ± 10.8
    450 ± 6.9
    1852 ± 13.5
    550 ± 8.2
    2047 ± 15.8
    650 ± 9.6
    2237 ± 18.5
    900 ± 13.6
    2697 ± 24.4
    Sorry if the scale looks a little jumbled but it breaks up as follows: (75 degrees F +/- 2.5 degrees = 1091 ohms +/- 5.3 ohms), (350 deg. F +/- 5.4 deg. = 1654 ohms +/- 10.8 ohms) etc.
What's the wiring diagram for a GE wall Ovens digital readout
There should be a diagram somewhere on the oven. Usually on the top or back or if not, inside the terminal block cover where the electrical supply wires go into the oven. Make sure its turned OFF before you remove any covers.
Mar 13, 2016 • GE Ovens
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
When my GE wall oven is in the middle of heating up, I get an F3 edit and the oven keeps beeping. I turned it off and then turned it on again and it seems to be heating again. What part should I look to...
Hello there:
Normally this is due to a bad temperature sensor F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and replace if found faulty
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
GE Profile Wall Oven Model JCKP16GS-1
It sounds like this is a common occurance among GE ovens.
Shut off the power at the box, then remove faceplate then remove the keypad.
after doing so, remove it from connector, and clean pins with an eraser.
Make sure the terminals are clean of debris, and check for a reset button on the back of the keypad.
I hope this helped you out.
GE Profile JT952 Double Wall Oven doesn't heat up adequately
heatman101
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
