Nikon Coolpix L11 Digital Camera Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a driver. Device manager asks for Nikon DSC coolpix L11 -ptp
satya prakash sahoo
Level 2:
Sergeant:
Champion:
  • Expert 214 Answers
  • Posted on Jun 28, 2009
satya prakash sahoo
Expert
Level 2:
Sergeant:
Champion:
Answers
214
Questions
0
Helped
65749
Points
546
Go to download.com there you will get your software with free of cost............enjoy :-)
1helpful
Where can i find software for Nikon Coolpix S3200 - precisely this - NIKON DSC COOLPIX S3200-PTP?
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Feb 19, 2013 • Cameras
How to take pictures from Nikon coolpix L16 to windows ME ?
Support on Windows ME for USB is poor. Your best shot is to go to the setup menu on the camera and select USB and then make sure it's set to "Mass Storage" and not "PTP". Then connect the camera.
1helpful
Picture project
Hit MENU on your camera, go to the setup menu and select USB and then make sure it's set to "Mass Storage" and not "PTP". Once you have done that you shouldn't need any drivers. The camera on this setting will essentially mount as a USB thumb drive.
Hope this helps and remember to vote. :)
2answers
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
2answers
Driver Installed
Diditial camera do not need 'drivers' for PC's operating with WinME/2000/XP/Vista
Windows does it all
5helpful
2answers
Need Nikon Coolpix drivers for Windows Vista
Windoze has issues with "PTP" mode. Go into the menu of the Coolpix, and find the "USB" menu option (you might have to dig), and change it to "Mass Storage". Plug it in, and Viola!
3helpful
2answers
Nikon l11 and mac drivers
iPhoto should not require any drivers for OSX. Have you hooked the camera up the the iBook?
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
1helpful
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
