SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
SOURCE: need to know what size and hoe to change belt for
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
SOURCE: what size drive belt goes on mtd mastercut riding
Visit mtd.com for an exact answer.
If you have the belt, take it to a auto parts or farm supply place for an exact replacement without shipping.
I hope this helps you
a
