Sony RM-V310 Remote Control Logo
A
Anonymous Posted on Jun 27, 2014
Codes tv for universial ge remote and codes for Toshiba tv
I have a ge universial remote i need the code fora dynex flatscreen tv dvd combo
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device Button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below. Codes for brands are located at the bottom of this link. http://www.directutor.com/content/ge-universal-remote-instructions
GE Universal Remote Codes and Instructions direcTutor
1helpful
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
My grandson broke my original remote control for my toshiba tv how do I program a universal remote to work
In the manual it self,give all the codes for ur tv,none of them work?No,one well give u any other codes will work for ur tv.Return the Universial remote.Try this website like Remotes.com to buy a original remote.Yes,it cost alot more than a universal remote,but it ur tv original remote.
1helpful
I have an RCA universial remote control and lost the paper that gives me the codes, i need to reprogram my remote, my TV is an Toshiba "big screen".
Visit this link. On the bottom right side of the page, it is written in red: "Find your remote codes here!", click on this and a new window will open.
Select your remote control model from the drop-down menu and you will be presented with its manual and complete list of available codes.
Help
Toshiba codes are 0517,0419,0512,0613,0719,0112,0506,0111,0618,0627,0437,0041,0094,0802,0313,0715!:-)
2answers
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
TV CODE
most universal remotes have a code serch feature, you should look in the book or online to see how to set it
2answers
Don't have codes
ge codes for mad catz universal remote: 029, 031, 007, 040, 027
instructions
1) Press the "TV" mode button
2) Press and release the "SET" button (You may need to use a paperclip or small item to do this.) - The controller will light-up GREEN
3) Press the first number of the TV code - the controller will illuminate RED
4) Press the second number of the TV code - the controller will illuminate AMBER
5) Press the third number of the TV code - the controller will semi-illuminate
6) lf the first code you try does not work, try the others
hope this helps,
trin
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
