Power Equipment Solutions 2002 Club Car DS Street Ready 48V Golf Cart w/Jeep Wrangler Body Logo
A
Anonymous Posted on Jun 24, 2014
CLUBCAR GOLF CART GOES RORWARD GOOD BUT SLOWS DOWN OR COPLETLY STOPS IN REVERSE
2answers
I have a Patterson Eventer golf buggy, it goes about 12 inches and stops abruptly in forward or reverse. What's wrong?
Question edited for clarity.
Question moved to golf.
Solenoid. (electro-magnetically operated switch)
What are the symptoms of a bad solenoid in a golf cart? On an electric golf cart, the most common symptom is the solenoid is not delivering electricity to the controller when the vehicle's ignition is turned on. In normal operating conditions, the solenoid clicks on and off with the ignition switch. A failing solenoid will generally not click.
https://www.google.com/search?q=patterson+golf+buggy+solenoid
If it clicks, it is more likely to be the accelerator potentiometer, basically the variable gas pedal. Great resource in the link for Golf Cart woes.
https://www.golfcartsforsale.com/blog/5-common-electric-golf-cart-problems-solve/
Mar 18, 2022 • Golf
What year is my golf cart 211648 ?
What is the make? Is it Clubcar?
Jan 19, 2020 • Golf
1987 owners manuel for a club car golf cart
Club Car Manual Club Car Serial Number Club Car
1984 2008 Club Car Golf Cart Repair Manual Download
Sorry, I can't find a free 1987 version. The first link is a way to directly order from Club Car. No way for me to know for sure but you might take a look for similarities in the following: http://www.clubcar.com/content/dam/cc-corp/documents/pdf/pdf/ownersmanuals/DS-Manuals/1014409%201287B00000.pdf
Aug 10, 2017 • Golf
I want to know the year of my ClubCar golf cart...ser#AG0313-267194
it is an 03 cart, first numbers past the letters.
Nov 01, 2016 • Golf
Troubleshooting gad pedal on electric clubcar
Not sure exactly what you mean. A model number will help so I might look at wiring diagram. Is the pedal a variable speed or maybe about 4 different set speeds? The model number will tell me. First thing to check is the battery terminals for good connection with cables and and make sure cables are clean.
Jul 26, 2016 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
3answers
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 • Golf
Top Power Equipment Solutions Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Power Equipment Solutions Golf Expert? Answer questions, earn points and help others
