Question about Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Posted by Jerry on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Posted on Feb 09, 2016
Do you repairs golf cart?
fixya does not physically do repairs were an online repair forum manned by volunteers
Sep 26, 2018 | Golf
1988 club car runs in reverse but not forward
If this is a 5 solenoid cart then I would look at the forward/reverse switch. Sometimes one of the copper contacts will get hot and melt the plastic around it, causing it to sink in and not make contact. I have seen this happen where the cart will move one way and not the other. Other times the contact is so burned, it will not make contact either direction. If the contact is burned then the only cure is a new f/r switch.
Sep 12, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
1984 EZ GO WILL GO NORMAL SPEED IN REVERSE BUT NOT IN THE FORWARD DIRECTION
I am guessing that your cart has 3 batteries on each side and the controls are between the batteries. If that is the case there is a reverse cable that is not connected to the main positive but to another positive battery post. If this sounds like your cart then I would check the condition of the batteries from where the reverse wire is connected and to the main positive battery. Some older carts use less batteries for reverse but uses all six for forward.
Hope this helps.
Aug 31, 2015 | Golf
Why does my golf cart battery charger turn off after 6 seconds when battery is partially discharged?
I have seen a charger turn off like that when there is one or more bad batteries. Try a load test on each battery to see if one is bad.
You can do this with a voltmeter. Connect the voltmeter to one battery and make the cart start to move and watch the meter.
If the voltage drops a lot then it could be defective.
Aug 30, 2015 | Golf
Club Car cart will not move forward---works fine in reverse
check the forward/reverse switch. Possibly a loose wire. Unhook the battery and go to each wire and verify it is connected properly. Then reconnect the battery.
Aug 15, 2015 | Golf
MY 1993 CLUB CAR GOLF CART WILL NOT MOVE, I HEARD A LOUD POP WHEN I WENT FROM FORWARD TO REVERSE/ANY SUGGESTIONS?
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Aug 06, 2013 | Dual Club Car Lester Power Drive Charger...
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
