Expert
- Posted on Jun 30, 2009
Re: I have a used air conditioner with no book--i need...
Thermostat shoud be on auto and cool. Setting is normally set at 75-78 degrees f.In the winter, keep it on auto and heat. Setting should be kept around 60-65 degrees f.
You are just having problems with the t-stat right? adjust the temp setting once it is satisfies it should turn off amount of time depends of how cold you set it. When you leave you can turn it up 5 degrees warmer to save some money but dont turn it off yes you save some $ but you spend it when the unit trys to catch up. Did that help?
what is the make and model number
