On tickover its fine but when revved it sounds as if something is griding at the casing, and high revves (when racing etc) its banging and grinding away?
Had a similer problem with my L1 recently and narrowed it down to the cluctch not getting enough oil through so changed cylinder put an ebc clutch in and serviced entire clutch system and thankfully seems of done the trick now no gearbox or clutch noise and goes throug the gears superbly with no slipping or noise even when going for it
SOURCE: clutch grind sound
If you have 1/8" to 1/4" freeplay in the clutch lever the cable should not be the problem. You had best check the gearbox oil level.
