Cars & Trucks Logo
Posted on Jun 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got a guy to change break pads for me on my car. breaks now drag
Changed disk pads on my car, when I drive the breaks drag until they completely hold. Took it back n the guy blead the breaks but I still have the problem. its causing the car to overheat as well because i have to press the gas hard to move. please help!
  • mike loshbough
    mike loshbough May 11, 2010
    sounds like he twisted one of the brake hoses
fordexpert
Level 3:
  • Chevrolet Master 5,692 Answers
  • Posted on Jun 25, 2009
fordexpert
Chevrolet Master
Level 3:
Answers
5692
Questions
Helped
1975987
Points
17063
Also check part numbers for the pads he put on. Then see if outside pads have a squeller clip on one end. The clip is there to warn of low pads. The clip may possibly **** the pad if it is put on the wrong side of the rotor. Jack up each front wheel and see if both are grabbing. If 1 side it would pull. Do not know if it is humanly possible to put the back pads on the front and vice versa. Twisted brake line suggested by other expert would be reason bleeding is not stabilizing. Sometimes there is a favored wheel you start with in bleeding because of the antilock stuff.
Anonymous
Level 3:
President:
  • Master 1,111 Answers
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381048
Points
3221
I assume you mean the front pads, because the back are probably shoes..is it both front wheels or just one? if it is the front brakes locking up, its either the hose to that caliper is collapsed or the caliper it self is faulty. if its the rear brakes, its possible they were put on backwards...little shoe goes toward the fron and the bigger one goes toward the back...maybe they were put together wrong..id say if this guy that did your brakes, cant figure the problem out, then he shouldnt be doing brake jobs!
4helpful
4answers
Why do the rear wheels get very hot at hwy speed after only 20 mi?
Replace the rear brake hose/s. They deteriorate on the inside and clog up. Not letting the calipers or cylinders to release. I recommend replacing the front and rear.
How to fix my front breaks?
Here watch this video
http://www.youtube.com/watch?v=kt2fvHlzv-4
Make sure you replace both your rotors & pads. Don't just replace one side.
1helpful
I change breaks pads on my 08 jeep compas after that i push pedal breaks end not i dond have pressure on pedal way? thanks
sounds like you got air in your brake lines from where you changed your pads thier should be a bleeder valve on your brakes get a friend to hold the brake pedal to the floor while you take a wrench and break the valve open when the pedal hits the floor close the valve just continue doing that until pure brake fluid comes out without air bubbles start at the master cylinder under the hood and don't stop until you have done all four corners if that doesn't fix it you might need a brake booster
3answers
2helpful
2002 tahoe breaks lock up during driving
It sounds like the rear calipers are bad. Raise the rear wheels and see if you can turn the tires. If you can't, open the bleeder. If you still can't replace the caliper. If you can turn the wheel after you open the bleeder, replace the brake hose to that wheel.
7helpful
2answers
Rear disc brakes drag after installing new pads
Just did my rear brakes this weekend, Monday had a very slight drag. Noted that when I installed new pads I had to tap them on. That shouldn't be. When brakes are released, there should be enough play to allow the pads to back off the disc. Tonight, I removed the pads and filed down the ends of the tips that go into the top and bottom channels until I could install and remove them with fingertips, that gives them enough play to grab and release. Drag disappeared; the old girl ran like she should.
Changing Brake Pads
Well the first thing U need to do is clamp off your break line,{u only have to do this if it has abs}which that year.then you nee to break open the break bleeder vavle.Whants you have don this then you are raedy to unbolt the break housing and remove the breaks and replace.Put back togather and close the bleeder vavle and take the clamp off the break line.Now you are ready to bleed the breaks.The same way for all four.{if your car has disk breaks in the back}
1991 explorer front brakes
take off the wheel there will be two pins that hold the caliper on drive them out with a screw dirver or punch that will free up the caliper and let you change the pads DO NOT let the caliper hang by the rubber break line beacuse it WILL break if you replace the disc also, you have to take 4x4 cam off and spindle nut off
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
