When I turn on the scanner the only available menu is the supplies menu. How to get the others to be available such as the admin menu.
SOURCE: HP 9250c Digital Sender
The CC543A is the approved CAC reader from HP. That is what we are using on these devices throughout our organization. The reason some CAC readers do not work is because the STIGS on the device from HP require that the device software for the readers also be used. The readers are about $300 each.
SOURCE: how to update the frame ware of our digital sender 9250c
the firmware probably does not even need to be updated unless you are having a problem
SOURCE: I am looking for a
here is the site for the driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3330760&taskId=135&prodTypeId=15179&prodSeriesId=3330619&lang=en&cc=us
Just be sure to select the operating system you are using and download the software.
Hope this helps!
Don't forget to rate;)
Gary
SOURCE: how can i configreation the digital sender hp
Can I set HP DS 9250C to scan to my C:\drive via usb?
If you need more help come back.Post /
thumbs / testimonial are
welcome!
