The light and fan go on and off randomly. I have removed the battery from the remote control and it still goes on & off randomly.
SOURCE: Remote Control Problem
you have a ground somewhere ... check the wiring. Most likely the ground shorted the signal sender.
SOURCE: Remote does not control the unit. Replaced
are you sure the remote is ok, the remote is the weak link, that is the first thing I would replace
SOURCE: Fan turns on randomly and will NOT turn off until
That sounds like a problem in the remote. I would check it for loose wires, cracks in the circuit board, etc. If there's nothing obvious (and there may well not be) the problem is electronic and would be nearly impossible to find and repair for most do it yourselfers. Your best bet would be to order a new remote. Good luck.
SOURCE: My hampton bay fan turns on and off with out
I doubt it is caused by IR(Infrared) Interference, since IR remotes have specific codes for each brand of device. Still try point another remote to it just to make sure such as the TV remote. Alhough highly unlikely it is possible to get interference from another remote control.
