Cars & Trucks Logo
G
GEOFF WINZAR Posted on May 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is water getting into the engine ECU. On my Citroen C3 1.1
1.1 petrol
_-__-___-_
Level 3:
  • Citroen Master 20,706 Answers
  • Posted on Jun 05, 2014
_-__-___-_
Citroen Master
Level 3:
Answers
20706
Questions
Helped
6804948
Points
57965
In the cab ECU, the window leaks (or door leaks if close to ECU)
under hood, driving too fast in deep water . or horrific fender rust.
you never stated a year, how are we going to guess that.
each generation of car the move the thing... (forward)
3 Related Answers
Anonymous
  • Posted on Jun 21, 2010
SOURCE: citroen zx immobiliser 1400cc petrol 1996
leave ignition on for 30mins
kirkx
Kirk Augustin
  • 2019 Answers
  • Posted on Mar 07, 2011
SOURCE: citroen c4 petrol engine will
Without being familiar with the Peugeot 405, I would assume it has fuel injection and a bad temperature sensor. Most sensors go to either 0 or infinite ohms resistance when bad, so an ohmmeter is necessary. A multi meter can be purchased from Harbor Freight for $3.
Other possibilities would be a lean mixture from a loose or cracked hose, clogged fuel filter, etc.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 06, 2013
SOURCE: (engine immobilizer fault) looking engine ecu for citroen c8 2003 2.0 16v auto petrol.brand magneti marelli 4mp2.06....or alternative solution?
I don't understand what you are asking, please clarify.
Citroen C2. Since I replaced blown ECU on it, the car's cooling fan stays on and the engine cuts off at 3000rpm.
Question edited for clarity.
The only way to diagnose strange things like that is to get an auto electrician to look at it. His pro grade scan tool computer can diagnose the functions of the ECU and all electronics.. New ECU need programming on the vehicle when they are replaced.
https://www.google.com/search?q=auto+electrician+near+me
Hi, I switched the battery terminals of my Citroen Xsera picasso, and now the car can't start. is the ECU burnt?
It's possible that the ECU (Engine Control Unit) may have been damaged when you switched the battery terminals on your Citroen Xsara Picasso, but it's also possible that the issue is related to the configuration of the ECU.
The P1613 error code typically indicates a fault in the configuration of the ECU, which can be caused by a variety of factors, including a dead battery, a faulty ECU, or improper programming.
Before replacing the ECU, it's a good idea to try resetting the ECU to its default settings. Here are the steps to follow:
  1. Disconnect the battery and wait for at least 30 minutes.
  2. Reconnect the battery and turn on the ignition.
  3. Wait for a few minutes before starting the engine.
If resetting the ECU does not resolve the issue, then it's possible that the ECU has been damaged and may need to be replaced. However, it's important to have the issue diagnosed by a qualified mechanic before replacing the ECU, as there may be other factors that are contributing to the problem.
If you do need to replace the ECU, it's important to ensure that the new ECU is properly programmed for your specific vehicle, as failure to do so can cause further issues with the vehicle's performance. A qualified mechanic or dealership should be able to assist with the replacement and programming of the ECU.
1helpful
I need a diagram to show me the routing of the petrol pipes on a citroen c3 from the petrol tank to the engine and back to the petrol tank please?
the fuel is constantly rotating round the fuel lines, the fuel is pressurized, so any fuel that is not used by the injectors is sent back to the tank.. this give a constant flow and pressure to the tank. the pressure in the tank is regulated by the pressure relay that lets air into the tank to lower the pressure. this is regulated by the ecu and your speed. if the pressure drops or is to high in the tank the engine can cut out on the fuel rail there is a fuel pressure regulator this keeps pressure on the fuel line coming into the injection system. some systems have duel line feeds from the tank for 2 rail systems, this system was not reliable due to the amount of feed pressure needed to fuel 2 lines. and can cause pressure leaks. some systems have a pressure regulator controlled by the ecu on the return line, this is more fuel efficient as it keeps the fuel at a steadier flow back to the tank and give a better fuel spray into the engine. hope this help you.
How to reset economy mode on my Citroen c4 1.6 16V petrol
knackerd battery can give same symtoms
start with a fully charged battery.....check all earths are good.
cheers
Where is the body ecu located
Engine ECU is located in the engine bay, on the driver side(RHD). Body electrical has no ECU (earlier models). Citroen Berlingo uses what is called 'Multifunction Control Modules'. It has 2 of them. One is located in the steering column switch assembly and the other is incorporated inside/underneath the fuse/relay frame in the engine bay. If your Xantia is late model, it may adopt the Berlingo system but I have not seen one that does.
2helpful
2answers
Citroen xantia fuel pump relay
If the pressure is up the pump will not cut in anyway! slacken off a fuel line to the injectors a little and drain a few cc of fuel out (it will evaporate fast) then try again, if the pump runs for a couple of seconds then look at the spark, if it doesnot the relay is above the fuses.
Top Citroen Experts
Thomas Perkins
Thomas Perkins
 Mikey
Mikey
Jonathan Buck
Jonathan Buck
Are you a Citroen Expert? Answer questions, earn points and help others
