The 3 beeps means that the freeze cycle is longer than 60 minutes. This could be because: float switch stuck, water valve leaking water into the sump, low on freon. If not one of those, it is a more technical issue that would require a service tech. Reset button is a small white button on the control board. Press it while the power is on to reset it.
SOURCE: Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
SOURCE: Hoshizaki ice machine with constant beeping every 3 seconds
I believe if you remove the thermostat wires and put them together and retry it you'll be making Ice, then get you a new thermostat. Please rate me accordingly and good luck.
SOURCE: Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
SOURCE: i have a hosizaki ice machine. the warning buzzer
check to see if you have the correct water pressure going into the machine. You need at least 30 psi. Also if your machine is water cooled, be sure cooling water is entering the machine. on water cooled machines there will be a continuous flow of water into the drain whenever the machine is running. If it is air cooled check the condenser coil to see that air is flowing freely through the coils.
