20 Most Recent Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Questions & Answers
hoshizaki ice maker kml 400 mae is not making enough ice after i cleaned it.
Hoshizaki... | Answered on Dec 17, 2017
as long as you recovered the charge, pulled a vacuum, changed the filter/dryer, and added the correct amount of refrigerant as a liquid, you should be good to go.
Hoshizaki... | Answered on Jul 07, 2017
I see this is from several years ago. if this is still an issue, let me know and I will try to help.
Hoshizaki... | Answered on Jun 17, 2017
usually from not enough refrigerant in the system. compressor overworking. excessive heat could also be from the compressor being bad such as bad valves. should be checked out by a service tech as this could involve removing freon to make repairs.
need more info on the unit. Model number would be helpful.
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
this machine is rated for 1,600 pounds of ice in 24 hours. would need more info to offer suggestions.
most all machines by Hoshi, the reset button is on the control board. take your time and look at it as it is labeled but is very small.
try resetting the the "reset" button on the control board. it may be just that simple.
this could be a large range of issue and too many to list for someone who may not be a skilled technician. I strongly suggest having a tech check it out as it may get into removing freon or more to make the repair. Sorry for the news.
check for a stuck water float. this usually, in most cases, is the issue.
What is your question about the switch? not very clear as to what you are asking.
Check to see how long it stays in the freeze cycle. normally it takes a least 20 minutes to make a batch. If less than that, you are probably loosing water causing an early harvest and almost no ice.
most of the time it is the water pump is going bad. It squeals real loud.
Look for a small button on the control board. just press it to reset.
First thing to check is the float switch. If stuck, it can cause it not to run.
Not real clear of your question but most machines have the control box in the compressor compartment. It has a switch that shows: Wash, Off, Ice. Your incoming electrical is on the rear of the machine. Hope this helps ya.
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Hoshizaki... | Answered on May 07, 2017
Replacing TXV
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
292 questions posted
Top Hoshizaki Freezers Experts
Dennis Boxerman
Joe Palazola
Marvin
Marvin
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
View Most Popular
Hoshizaki Freezers
  • Hoshizaki Freezers
Most Popular Question
model
  • Freezers
