Have the engine codes accessed. May be a hard fault code there to begin diagnostics.
Access codes after stalling,also.
SOURCE: 1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
SOURCE: does the 96 neons have a speedometer cable??? if so how do you change it
How handy are you? Takes about an hour total to fix & no dirty hands. I had to do my own fix to my 95' neon about 3 times & on the last one I tried something different & never had a problem again, & sold it about 3 years later still working. If your up to it, I'll give you instructions. You have to pull speedo cluster out of dash , but it's pretty simple really. Let me know.
SOURCE: 87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
SOURCE: 1989 plymouth sundance obd1 code 11 car dies when
The code 11 is referring to your coil pickup.This is located under the distributor cap and rotor,and is held in by the distributor cap itself.Being electrical when it gets hot the sensor brakes down .The pickup is not very expensive at all:)
SOURCE: 96 f350 diesel stops after warm like key turned off.
Several possibilities: 1) PCM or idm relays cutting out when hot, but said it's good, but double check anyway. 2) Possible IPR regulator o-ring, losing it's seal after oil gets thin, and or connector loose or bad from vibrations. 3) Possible cam sensor intermittent failure 4) Best to hook up a scanner and observe engine data to eliminate costly guesses. 5) High mileage vehicles, check ignition switch. 97 F-350 565 EFI Big Block
