SOURCE: where can you buy a fuse for the sanyo DP26640?
What rating is the fuse? It should be printed next to the fuse or fuse holder. We will need this get help you get the right one.
SOURCE: My Sanyo DP26640 will not come on
Look for any loose contacts in power outlet.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
1. Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3. Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4. Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
