Question about Sanyo DP26640 LCD TV
For the last few months when I turn the tv on it would take about 10 seconds to come on or longer. Then one day, I turned it on the green light came on but the picture never played. I repeated that step several times then the green light stopped coming on and of course now picture.
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
SOURCE: TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Posted on Oct 11, 2009
SOURCE: tv turned off while watching it and wont come back
What was the previous problem and solution? is this a different problem than before?
Sounds to me like power isnt getting to the components.. at least to operational voltage where it will illuminate the pdp modual.(screen)
To fix this alot of troubleshooting is required because of the various things that can cause this.
Knowing plasma's pretty well , i am prone to blame this on heat. The lack of engineering prowess has flooded the market with disposable junk without any cooling whatsoever..i can heat a room with my plasma.
So lets see here.. power board could have blown a fuse, a peko hardwired fuse but this will cut all power to the rest of the set. Do you get sound? do you get a series of blinks from the tv's front panel? if so count them..its a error code... if you dont even get power lights..you pwb ( power supply) is dead.. either the secondary side or primary of the board..it has 2 phases to it. primare and secondary.
if the tv doesnt even fire and its completely dead...pwb.
need to know what functions the tv can do right now.
Posted on Dec 14, 2009
Testimonial: "power board is completely dead, no blinks, nothing, its like its not even plugged into the outlet. the first repair was for exactly the same thing."
SOURCE: My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Posted on Feb 28, 2010
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
