do one thing just take out ur battery and then put it again and dont power it on..just connect the charger and leave it for atleast 10min, and then try to power it on.do one thing just take out ur battery and then put it again and dont power it on..just connect the charger and leave it for atleast 10min, and then try to power it on.
You can't post conmments that contain an email address.
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall.
ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
