2005 odyssey brake lights are not working. The only working brake light is the middle brake light. I suspect it is a blown fuse. Can anyone suggest which fuse I should replace? Thanks in advance for the help.
how about the switch of the bottom of the brake pedal ck there , might be a bad ground wire jump it out with one and see what happens , see if you are getting power to the red wire while the pedal is depressed in the back , if so your light sockest could be bad , but highly unlikly
suspect a bad brake light switch,on the brake pedal itself.the key need not be on when checking the brake light switch.but requires 2 people.one to insure the brake lights come on,one to push the brake. theres a switch on the brake pedal itself. look above the brake pedal pad that you push to apply the brakes. you will see a plunger that moves in and out,just to supply the current to the brakelights.if the plungers out of sync,it will not work. or it may only be stuck.or simply bad,if it moves and brake lights do not work. if the plunger works on visual inspection,and is plugged up,the switch is suspect to be bad. thank you,for choosing fixya.com!! SIMPLE SOLUTION,CHECK THE BRAKE LIGHT FUSE. IT MAY ONLY BE BLOWN. UNDER THE DASH ON DRIVERS SIDE CLOSEST TO YOUR LEFT FOOT WHEN APPLYING BRAKES. WITH FLASHLIGHT,CHECK FOR BLOWN BRAKE LIGHT FUSE. if this fails,check for blown brakelight bulbs. unlikely that both brake light bulbs blown at once! but not unusall. thank you for choosing fixya.com!!
I would replace the fuse... and then have someone stand to the rear of the vehicle and watch the lights come on as I applied the brake... if the fuse blows again... note which tail light did NOT come on durring this test and replace the bulb.. it is grounding to itself and causing the short.
Try cleaning the contacts with a wire brush if they appear dirty and then apply a small amount of silicone to the bulb contacts also try replacing the bulb as sometimes they don't appear to be blown but are
