My Hitachi Air Conditioner is leaking water. I want to take it out and fix the drain pipe. However , I cannot find any screw on it to take it out. Please advice.
There is a bracket that is hung on the wall then the unit is hung on the bracket, it should lift off the bracket by pulling out on the bottom and lifting up. careful of the copper lines. you may want to try connecting a shop vac to the drain line where the water drains, make sure you seal the suction well with duct tape or something and try that first, it should clear it just fine
SOURCE: Hitachi RAS-10C2M. What size of air conditioner
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
