Question about Hitachi Heating & Cooling
Hitachi RAS-10C2M. What size of air conditioner
Hitachi RAS-10C2M. What size of air conditioner is this? 1HP?
Posted by chillyred97 on
Anonymous
    New Friend:
  • 66 Answers
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
Posted on Feb 23, 2010
Remove Hitachi RAS-10C2M
there is a bracket that is hung on the wall then the unit is hung on the bracket, it should lift off the bracket by pulling out on the bottom and lifting up. careful of the copper lines. you may want to try connecting a shop vac to the drain line where the water drains, make sure you seal the suction well with duct tape or something and try that first, it should clear it just fine
May 11, 2014 | Hitachi Heating & Cooling
I have a "Hitachi split type air conditioner model RAS- 3098U", and its started leaking today from the right side. I didn't install it and I can't figure out how to remove the front cover to l
water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
Aug 13, 2012 | Hitachi RAS-09UH Air Conditioner
Hitachi A/C. The green light of air filter indicator is on.
When its turn off, not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Aug 10, 2012 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
We have a Hitachi Model RAS-63CHA2 that we need to find out how old the unit is as it has broken down. Can anyone tell me when these models were first produced?
This model was produced approx 6-8 years ago a common problem is the compressor capacitor 50uf. I must of changed 50 of them by now.
Jan 19, 2011 | Hitachi RAS-09UH Air Conditioner
I need a service manual for Hitachi airconditoner model RAS-4HQE5
Hello, I have this manual but it is downloaded at a 3rd party site where I store my info. Go to the supplied link, follow the Hitachi file. Note - there are a few annoying pop ups, b ut be patient and you will get the file. http://www.mediafire.com/?mreiznz5mtz
May 13, 2010 | Hitachi RAS-09UH Air Conditioner
Hitachi ras-5h gse
first: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Sep 05, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
196 people viewed this question
Top Hitachi Heating & Cooling Experts
Lawrence Oravetz
jws1013
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
