If you have the disk that came with the PC, just re-install it.
Call Dell for help, if you purchase a new hard drive from Dell will walk you thru the installation.
Hope this helps.
Depending on the desktop you could add a new hard drive and make it the OS/Boot drive with Win 7. Your old drive with the pictures on it will become a data drive. If you don't know how to make the new drive the boot drive or the desktop does not have room for a 2nd drive it might be a lot easier to take the old drive and put it in a USB external enclosure.
Malwarebytes is good cleanup utility.
Do not use IE, to many vulnerabilities, Chrome of Firefox is better..
Not sure the connection between changing broadband providers and passwords.....
SOURCE: stuck in safe mode with black screen
spywaregard 2008 is malware, a parasite if you will
http://www.pcthreat.com/parasitebyid-7159en.html
the last 1/2 of this article will run down a list of files you need to delte to get rid of this nasty little bugger. You can also download various tools to remove it, but it is dependent on your comfort level. if you are comfortable searching for files and changing a couple of registry keys, then by all means, manually is the way to go. If not, you will not have a hard time finding a tool to get rid of this
