Computers & Internet Logo
Michael Ridgel Posted on May 09, 2014
How do I download browser for afce.radiantenterprise.com
I want to try to replace a capacitor, TT 10000 AFC, 35+5UF 440V, 50/60HZ, 70C. What is best place to buy?
Amazon for less than 20 bucks. It depends what is wrong with the AC and why you are considering changing it? The capacitor starts and runs the compressor motor.
https://www.google.com/search?q=capacitor%2C+TT+10000+AFC%2C+35%2B5UF+440V%2C+50%2F60HZ%2C+70C
I have error code 114 on my American standard a/c. What does that mean?
114 is a communication error in the air handler. It can be the afc board, the blower motor or both. Cycle power to the AHU by the breaker. Leave off for about 10 seconds. If error comes back you will likely, at least need an afc board.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
How to download browser for afce.radiantenterprise.com
Please click at this link to be able to browse the site without installing Internet Explorer http://www.similarsites.com/site/afce.radiantenterprise.com
Hope this can help you...
Heating furnace blower won't stop
Check out the afc could be dirty remove and clean back of it , or replace afc , also check fan on fan off settings on afc
My Coleman direct vent forced air furnace 7995-656/D will fire up but the auto fan does not come on. I can cheat this by cutting the fan to on after the burner heats up. Whats my problem?
two things the pressure switch not working or the fan control afc not working could need cleaning at the back of the afc try this the afc works on temp rise to bring on the fan afc temp fall to shut of fan so it sound like the afc is not coming on at temp rise, also check if air filter is clean
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
My Coleman DAGT gas furnace blower fan will come on at time when there has been no heat cycle or will stay on after heat cycle is done. I have replace the the themostat and put in new intregated control...
try looking at the afc the fan control might need cleaning at the back of it could be filled with dust, or blocked air filter afc works on temp rise to start fan running and temp fall to stop running check settings on the afc thhey should be in your manual or afc might need changing
Grand Canyon Tech
Grand Canyon Tech
