If you cant send messages but can receive one using your nokia s60 phone, you phone's internal memory may be full with unused files. You need to refresh your phone's memory. Simply restore it to factory settings. (Hard Reset).<br />By resetting your phone, this will delete all the data on your phone so don't forget to back-up your files and remove it before resetting your phone.<br /><span>Switch the phone off. Press and hold three keys together, the green key, the * key and the number '3'. While you are holding these keys, switch the phone on. Don't release these three keys before you see the Nokia logo.</span><span><br /></span><span>or just simply dial *#7370# on your phone's home screen.</span>
<br />
<br />
<span><br /></span>
Hi, i think your message memory is full,that's why you received a message to your out box,try to my advice you need to delete all you messages to your inbox or all messages memory.if ever is not work it,try to reset your cellphone.but before you reset you need to back your files and contacts you need to save all before you that reset your cellphone.reset or manual reformat *#7780# and default password nokia 12345. i hope its work.thanks :)
Hard reset your phone. This will delete all the content of your phone so remove your memory card before resetting your phone. On the home screen type *#7370# .
The problem is that your inbox might have become full due to messages and received files via bluetooth.. try deleting some received files or clear all messages inside your inbox to free up memory on your phone..
This problem is mostly caused by memory corruption or insufficient memory. Check your call logs, sms, bluetooth receive sms or files, outbox, sent items, received files and delete or move if there are some which you suspect the cause of the occupied memory. Reset you phone to full factory (Reset Factory). Then restart and see the problem whether it is gone or not. If not Try backing up your files (contacts, messages) using PC suite to your PC. Remove your memory card, scan the memory card with updated antivirus, or format if necessary. Still you are getting the same error message? Remove your sim card, memory card and reset you phone using the code*#7370#. Sometimes, even updating firmware is effective. To do this, you need to go to the repairing shop. Good luck..
That message simply tells you that your phone memory is full and needs to delete some data in order for the phone to receive an incoming like messages or any multimedia files. Delete some unnecessary files on your phone to free up some space for other important files. Go to your phone gallery and then delete some files located in your phone memory and then restart your phone.
Try to delete messages, those are not too important to you. If you want to make the process quickly, try to delete video file or picture files, those are not too important to you. This way you can free up space in your memory especially if this is built in.
And for hassle free, don't overcrowd your memory of too much application, message, picture or video file. You gonna delete some of it or backup it up from time to time.
