Question about GE Profile PDW8400J Built-in Dishwasher
Any videos on float for ge dishwasher - GE Profile PDW8400J Built-in Dishwasher
GE dishwasher model number GHDA480N10WW doesn't fill with water.
check the float switch usually located in the front right of the dishwasher it should move up and down freely sometimes crud will get under the float and hold it up so the dishwasher thinks its already full.
Nov 02, 2013 | Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwasher has no water
Find out where your water supply is turned on to your dishwasher. Usually it is under the sink and make sure the valve is turned counter clockwise to supply water to the dishwasher. If this is on, on some models there is a float switch that will sometimes get stuck in the overflow position. Look in the bottom of the dishwasher tub and you will see a round float. Usually it is in the front left of the dishwasher. Move the float up and down and you should hear a clicking noise. Make sure float stays in the lowered position, closest to the dishwasher floor. Check those two and let me know what you find. And we can go from there.
Apr 01, 2012 | GE Dishwashers
Suds, overflowing out of dishwasher
Its old get a new one these are not designed to last more than yours did.
May 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Does the GE Nautilis have a water solenoid valve?
Yes and it is item number 744 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218471&diagram_id=22281725#d22281725
Close up:
http://www.appliancepartspros.com/part_details.aspx?part_id=2039343&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5218471%26diagram_id%3d22281725
And controlled by the float switch in the front left corner of the tub. If the float sticks there will not be any water supply.
Item 302 of the first link is the float dome and item 305 is the float. Don't be afraid to check to see that when the float is lifted up and down you hear a micro-switch click.
Thanks for using FixYa.
Kelly
Mar 14, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher turns on but no water is going into the dishwasher it is a GE potscubber 970
As there is no water entering the machine, check ;-
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
GE Profile dishwasher not drawing water from water line
If you look inside the dishwasher paying special atention to the left front corner. Remove the lower dishrack and then you will see a dome shaped piece of plastic attached by one screw. Remove this screw and check and see if the float is gunked up. Sometime you have to remove the lower access panel to remove a little pal nut off the bottom of the float assembly to actually remove it to clean. Clean it real good and reinstall. This should solve your problem.
please mark my answer as a fixya! thanks.
Mar 12, 2009 | Dishwashers
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
GE Profile PDW8400J Built-in Dishwasher Logo
24 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
