Question about GE 24 in. GSD3400G Built-in Dishwasher
Ge potscrubber 800
Cap fill melted
PixelRogue
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Posted on Apr 11, 2016
3 Related Answers
Daddy2keagan
Nathan Van Boven
  • 206 Answers
SOURCE: GE potscrubber 1200. Fills
Hi... No there is no another control ....The main control board time fills it!! So that means you have a bad valve ....If I were you I would get a new water valve
Posted on Apr 08, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: GE Potscrubber 1200 fills up with water, then just
Hello, henrych
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Tom Chichester
  • 55403 Answers
SOURCE: I need a new upper and lower rack for GE Potscrubber 600
Appliance parts supplier
Posted on Sep 20, 2012
GE potscrubber 900 motor sounds jammed. Motor starts humming and does not seem to start filling
motor hums indicates a faulty start/run capacitor
get in an electrician for a proper diagnosis
Aug 02, 2018 | GE Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
GE potscrubber 1200. Fills only partway with water. Holding down float switch makes no difference. Is there another water level control somewhere?
Apr 07, 2011 | GE Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
GE Potscrubber 800 Leaks
See if your parts store can mic the oring and match it to one
If you need further help, reach me via phone at https://www.6ya.com/expert/grayson_15ffad3aaeb66fef
May 01, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
GE 24 in. GSD3400G Built-in Dishwasher Logo
67 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
