Aiwa stereo system keeps shutting off when i turn the volume up... can anyone help
Sounds like system overload, Your stereo system has a protect on the amp to keep it from overload, so if it is shutting off you may need to unhook all your speakers, check all of you positive and neg wires and make sure all reds and blacks go to the right spot. Try lowering the bass and check to see if a certain speaker is the cause you may have two wires crossed. This is normal for some newer amps, They used to put fuses in these amps now it has a protector built in to make sure you don't blow out your channels. You may have a blown speaker in the mix that is causing this also you can try using crossovers on all your speakers.
