FIRST, IWOULD NEED THE MODE # AND TYPE(LCD,LED,OR DLP) AND WHETHER THE BLACKOUT IS FROM TOP TO BOTTOM, FROM LEFT TO RIGHT OR ON ONE SIDE ONLY. FIND THIWS INFO AND LET ME KNOW!
Possible failure of the display unit , it can be failure of the LCD so it is good to confirm the fault with a visit to the Nokia care for estimate as nothing else but a replacement is possible.
If however there is no display fault a resetting can solve or a reinstallation might be needed.
Try a SoftReset . Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
• To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
• If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
• While the backlighting is turned off, the function indicator
its a high voltage on the responsible chip of display maybe u need to service that phone cuz u cant afford buying a LCD just for testing that is not a deal with LCD.
