Saws Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear pulley arbor to short
I have a craftsman 8'' table saw that the rear arbor is to short to hold the pulley on properly. One can I still buy parts for a model number 10102141 and also where can i find a repair manual for this model of table saw? I bought this off an older man who was parting with it and he did replace the motor but the rear arbor is to short and the pulley works lose and comes off.
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Jun 23, 2009
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1311894
Points
5445
Got bad news from Sears on this one, they say there are no serviceable parts for this tool and to contact them. Sorry I couldn't help more.
Loose pulley arbor
I had a similar problem and after removing the suspect pulley I discovered that the threads for the set screw were not tapped all the way through. The set screw would tighten but not go far enough to lock on the key. With the pulley off the arbor I forced the set screw until it threaded well into the key way. I had to use quite a bit of force to get it to go but it finally pushed through the last portion that was unthreaded. Then I reinstalled it on the arbor with the key and tightened it. It has been months now of steady use without any movement.
2helpful
I was recently given and older Craftsman 10" table sawa. It worked great for cuttin some 2x4 and now all of a sudden it will only cut part way7 and than stops, and it smokes--Help!!
The problem could be one of the following:
1) dull blade, in which case replace with a carbide-toothed blade
2) underpowered or old/faulty electric motor
3) faulty/worn belt, in which case replace with new belt
4) The pulley on either the motor or the saw arbor (where the pulley attaches underneath the saw near blade) could be loose. Tighten down set screw.
5) The saw fence isn't set straight causing the wood to jam as you push it into the blade. Check this with a framing square and readjust so it is at a 90-degree angle to the front of the saw table.
1helpful
My saw problem has to do with changeing the blade. I'm useing a thin kirf blade. When I change the blade I have to put a wrench on the arbor next to the pulley to keep the arbor shaft from turning when I...
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
Recently I cleaned and lubricated my 4 year old Craftsman cast iron table saw. I did such a good job that I created a problem which I never had. When I am running with a dado blades, the arbor will slowly...
There should be a locking knob on the front of the crank or a locking collar behind the crank depending on which model or age of the saw that you need to tighten down to lock the arbor height.
1helpful
The pulley attached to the arbor for the belt on my 15 year old table saw keeps flying off. It is the type with a metal spline that goes into a slot in the drive shaft and two hex screws to hold it tight....
Sound like a nasty problem. Something has to be wrong, maybe the keyway is cammed out on the arbor shaft?? Did you try some lock tite, on the set screws, then I am guessing you got the set screws tight for sure? I know thats not easy. I deal in table saw parts on ebay as "Hokienpokie" if you need to try a different arbor assembly I should be able to get you one with your saw model #, Jim
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 • Sears Saws
What is the proper way to attach the pulley to the shaft of a Craftsman Table Saw? What size and style 'key' does the shaft take that the allen screw tightens down on to stay on the shaft?
At the arbor end it should be a curved 3/16" key. At the motor it will be a square 3/16" key. I would guess these should be available at most hardware stores, but I would have both types & most other parts too. I sell craftsman table saw parts, you can contact me via email [email protected]
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
1helpful
How do you remove the arbor assembly on a craftsman 10" table saw
go to sears service center and get a new arbor, and ask them to show you the motor and arbor assembly drawing. it should show how the arbor is attached to the shaft.
you can pull the arbor off with a pulley. you can get that from auto parts store.
Top Craftsman Saws Experts
Sean Wright
Sean Wright
john h
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
