SOURCE: reciever goes into stanby mode after 30 seconds of being turned on
No. If your using all the speakers that came with the unit, and unit was working correctly before then, your problem is an indication of a more serious problem about to occur. Your unit is detecting an over current situation. It could be something like a idle bias problem, or alighnment, or theres a part thats going bad and not up to specs. Oh Yes and one of your speakers could have a problem and just hasent went bad all the way yet. If it was my reciver , I would have it bench checked with some resistive loads and see on the scope, where the units clipping, if it is. If not the tech will know if its a zero crossover, idle bias or an offset thats bad. Without the proper equipment this is not a repair for you to attempt , unless of course you happen to be an electronic tech? Good Luck
SOURCE: TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
SOURCE: washing machine
remove the left and right edge trims on the control panel
remove the phillips screws under the edge trims
raise control panel ~1 inch and flip over backwards.
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
SOURCE: pool about to overflow
Syphon it (see link). It will be easier if it is an above ground pool.
http://en.wikipedia.org/wiki/Syphon
SOURCE: the treadmill keeps stopping Freespirit Model 12230520.0
Hey there,
If your treadmill has an optical speed sensor and hasn't been cleaned
for a while, dust, dirt or lint may be obstructing the infared eye of
the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may
have a loose wiring harness that would cause the same problems. Open
the motor case and verify the wiring harness is plugged into the lower
board snugly. Also, remove the upper console and verify the harness
is plugged into the back of the console snugly as well.
Definitely,
inspect the components and try and isolate the source of the problem
yourself first, before contacting a dealer for parts, as they can cost
a fortune..
Good Luck!
Chris (ziraffa)
