So i bought some euro head lights from ebay and was wondering why the right low beam was brighter than my left low beam the highbeams are perfect but i am having a problem with the low beam please help...
You have a bad ground on the left low beam. Using a test light connected to ground see what wire is positive with low beams on. Using a piece of electrical wire connect one end to ground and with the headlight connector connected to the headlight and headlights on stick the other end into back of the connector at the ground wire. If the light gets brighter, you can cut the original ground wire to the connector ( 2-3 inches from headlight connector) and run a new wire from ground and connect it to the wire at the connector. Hope this is helpful.
so your saying that my left wires are messed up that i have to replace them?? because they came with new wire harnesses but i didn't think i had to change them so should i just put in the new wire harnesses?? or what do you think i should do? and you say that i should check the voltage on left bulb to see how much is running? and how much should be running
